bored motor
Old Nov 23, 2007 | 09:20 PM
  #21
dcohen's Avatar
dcohen
Default RE: bored motor
i thought the k-codes had 4 bolt mains....but i have been wrong before
glen would know, but he never comes around anymore
Old Nov 23, 2007 | 09:37 PM
  #22
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: dcohen
no, just heavy duty main caps like the mex 302's and the boss blocks had 4 bolt mains only fac production 302 to have such the hi-po 289 blocks were suppose to have thicker main caps and thicker webbing castings up to the cam journals
Old Nov 23, 2007 | 10:10 PM
  #23
dcohen's Avatar
dcohen
hm, thats good to know, dunno why i thought they had 4 bolt mains[]
Old Jan 16, 2010 | 09:46 PM
  #24
5.0Tech17's Avatar
5.0Tech17
Default 40 overbored questions for 302
I have a 302 block that is 40 over do you think that is too much bore for a turbo or too much bore period or am i safe
thanks
Old Jan 16, 2010 | 09:52 PM
  #25
1slow67's Avatar
1slow67
ROTM Moderator
Safe bore is up to .060 over so you should be good. I would get your compression ratio to figure out how much boost. If you have a high compression ratio you can't run as much boost as you could would a lower compression ratio.
Old Jan 16, 2010 | 10:14 PM
  #26
FoMoJoe's Avatar
FoMoJoe
I had a 289 that I was gonna rebuild due to a busted piston ring (blow by) but after contacting a previous owner he told me he bored it .30 over. For spending the money at the machine shop to go .40 over, I didn't feel like having issues so I went with an 86 block with one piece rear main seal and had a 347 built. Fordstrokers.com built a long block shipped to my house for $3K. Cant beat that. Check out their Liberator.
firehorse02
Nov 16, 2015 11:28 AM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
