Classic Door Hinge (Latch) Fix
Old Nov 26, 2007 | 11:07 AM
jrrhd73must's Avatar
jrrhd73must
Default Classic Door Hinge (Latch) Fix
I figured out a cheap fix to classic doors that won't shut. When we shut my daughter's 67 Cougar door, it would not stay shut, we had to hold it shut and then push the lock button - I am sure that the mustangs and cougars had the same hardware. The inside cam door hardware is like $70. So I pulled the old one and figured out a inexpensive fix for it. Her are two pictures, the first is of a left side assembly with the broken spring. The second picture is of the right side assembly, with a new spring. I bought a spring from Lowes and cut it to fit. The fix worked perfectly.
[IMG]local://upfiles/16459/99D297FD0F0A4BA48F499726BCBCA4AA.jpg[/IMG]
[IMG]local://upfiles/16459/CBBF57F3E92749D6A1857640BB12C22A.jpg[/IMG]
Old Nov 26, 2007 | 12:25 PM
zmetalmilitia's Avatar
zmetalmilitia
Default RE: Classic Door Hinge Fix
nice job!
Old Nov 26, 2007 | 01:27 PM
RolandT3Speed's Avatar
RolandT3Speed
$70 is not too much to pay for your daughters safety!
Old Nov 26, 2007 | 02:15 PM
shr's Avatar
shr
+1 if it was my car i would probably do it but not my kids car!
Old Nov 26, 2007 | 09:58 PM
4reboy's Avatar
4reboy
its just a spring i'm sure its just fine, mine used to come off when i rolled down the window (happened like twice, never while driving). Just make sure it is fully secured and wrapped around the hole and i'm sure it will hold up.
Old Nov 26, 2007 | 10:09 PM
JMD's Avatar
JMD
Good fix JRR.
And yes, I approve, and the repaired latch is almost certanly not made in china....
Old Nov 26, 2007 | 11:02 PM
jrrhd73must
If the spring were a structural component, it might matter. However, look at the thickness of the spring in picture one verses the thickness of the spring in picture 2. The spring holds the cam engaged so the cam is the part with the stress on it.
BTW I am a senior mechanical engineer, and theDirector of Engineering,for a major company, specializing in aircraft modification.
Old Nov 27, 2007 | 08:56 AM
TexasAxMan's Avatar
TexasAxMan
You are referring to a LATCH, not a HINGE as the title suggests. Either way, good job.
Thunderball
15
Nov 22, 2015 11:49 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:58 PM
