Paint Removal
Old Nov 27, 2007 | 11:23 PM
mystangsbroke's Avatar
mystangsbroke
Default Paint Removal
Ive been sanding paint off the roof of my 66 and I have9 layers of paint and primers to remove. My question is can I use any strippers and if so what kind? Also if I use a striper what will be needed to get the metal clean afterwards? Thanks for any ideas.
Old Nov 28, 2007 | 12:42 AM
gooser's Avatar
gooser
Default RE: Paint Removal
aircraft paint remover. water. brushes on thick. very toxic stuff. will burn any skin it touches.
Old Nov 28, 2007 | 12:59 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if u lay plastic wrap on top of it it will sit without evap longer
Old Nov 28, 2007 | 12:03 PM
mystangsbroke
How much trouble is it to clean after you use these strippers? Thanks
Old Nov 28, 2007 | 12:27 PM
RolandT3Speed's Avatar
RolandT3Speed
20 grit sandpaper and a angle grinder. Nothing works faster!
Old Nov 28, 2007 | 02:35 PM
JMD's Avatar
JMD
ORIGINAL: mystangsbroke
The residue will wash off with soap and water, it will not pose any problems, used it many, many times without issue.
You may need to apply more than once since you have such a heavy accumulation of paint.
+1 on RModel65's recommendation on the plastic....
Old Nov 28, 2007 | 03:04 PM
jlg2002's Avatar
jlg2002
ORIGINAL: RolandT3Speed
Be real careful if you use this approach , lots of clean up sanding will be required to take the marks out left by the 20 grit.
Old Nov 28, 2007 | 03:11 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
id rather use a bondo hog and some 80 grit or maybe even some 36 before id ever uses a grinder that will make a mess
Old Nov 28, 2007 | 07:33 PM
6marc5's Avatar
6marc5
Like most of these guys above,I used aircraft stripper. The stuff I bought was in gel form. It worked great even though my car had about 4 coats of paint on it. I think Rmodel65 hit the nail on the head with the plastic wrap........ it's a good idea.
Old Nov 28, 2007 | 07:38 PM
mystangsbroke
Thanks for all the info. I think I will try the stripper. Their is so much paint on the car I dont think I could get it all sanded off in the door jambs and other tight spots.
