candy apple red
Old Dec 1, 2007 | 05:46 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: candy apple red
ORIGINAL: slick66stang
too many ants around here to get my car candy
nice[8D]
this is a car i did all the body work on it has a gold base with a blue kandy over it resulting in a teal
[IMG]local://upfiles/23144/7C291D6611B64EB3B70C9E63159CFDCF.jpg[/IMG]
Old Dec 1, 2007 | 05:52 PM
slick66stang's Avatar
slick66stang
how many coats should i do on color and clear to get a mirror image surface
Old Dec 1, 2007 | 05:56 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
id do 4 on the color id do 2 let it sit for an 30min-hour or so then wet sand the base with some 800 wipe it dry then tack it after its dryed for a while then 2 more coats of base let then id put 2-3 coats of clear depending on what your using just make sure its got the right hardners and reducers for the temp of the booth
Old Dec 1, 2007 | 06:05 PM
slick66stang
were getting the supplies from a paint shop that we know the owner so hes hookin us up on everything. so 4 coats of base and 2 on clear would give me a mirror paint job
Old Dec 1, 2007 | 06:12 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
depends on if you lay it out slick or not on clarece but 2 should 2 it then you can wet sand+ buff it to flatten it all out thenhave a nice super slick job
Old Dec 1, 2007 | 06:17 PM
slick66stang
if i lay it out slick would that be better?
Old Dec 1, 2007 | 06:20 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah less orange peel ftw but u gotta do it without running it
Old Dec 1, 2007 | 06:24 PM
slick66stang
what color primer should i use?
Old Dec 1, 2007 | 06:25 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
grey yellow what ever you want try to stick with the same paint company though
Old Dec 1, 2007 | 06:33 PM
slick66stang
ppg is the paint comapny. my car is grey primer i want to go with yellow primer though
