Tri Y problems
Old Dec 2, 2007 | 04:52 PM
sixt5's Avatar
sixt5
Default Tri Y problems
anyone have tri y's that hit the fenderwell and pitman arm? i have a set of ceremic ones from Patriot and they hit, had to space the engine up to keep from hitting, and they are starting to rust...
are there any others that are known NOT to hit? Hookers?
Old Dec 2, 2007 | 06:11 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Tri Y problems
mine hit the pitman are at full turn and also the zbar linkage i dimpled the header around the zbar i havent done anything withthe pitman arm yet though i got the cheap 100$ set from npd
Old Dec 2, 2007 | 07:21 PM
LCC's Avatar
LCC
Great, I just ordered a new set of Doug's headers (tri-y) which are now owned by Patriot. I'll let you know if they are any better.
Old Dec 2, 2007 | 07:38 PM
sixt5's Avatar
sixt5
you have a 68, you have WAY more room in there then me.
BEAUTIFUL car btw, what color is it? almost a DSG color
Old Dec 2, 2007 | 08:43 PM
noroof66's Avatar
noroof66
I went through 2 sets of the ceramic Patriots a while back and had nothing but problems. Could not get them in at all. One set was up against the shock tower, and the other pressed up against the starter. Ended up going with ceramic Heddman that slid right in w/out any problems.
Old Dec 2, 2007 | 11:37 PM
ky's Avatar
ky
America ftw
mine hit the shock tower too. so i machined a 1/2 inch spacer to go between the engine and the motor mount. it raised it up enough so the headers wouldnt hit.
Old Dec 3, 2007 | 10:17 AM
UBY289's Avatar
UBY289
Put them on my 67 ,289 Coupe, they went on Ok, but the Pitmam Arm hits at full turn and they leacked do to a bad factory weld that took me a whle to find. When I bought the Tri Y I was hoping for less trouble but it didn't work out that way.The car run really well with them.
stormesixx
Aug 25, 2015 09:11 AM
DrunknRuckus
Aug 23, 2015 10:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
