almost ready!
Old Dec 2, 2007 | 06:44 PM
eZ's Avatar
eZ
Default almost ready!
got my car running real well today. I put a spacer on the carb. why? i have no idea. dont even know if it will help. the rims are only temporary. had to use spacers to let them work. I think i went too low in the front. I did the shelby drop, 620 springs with half a coil cut. even if i go to a smaller tire i think they will still rub, gonna undo the shelby drop. Rear will be dropped one more inch. it has mid eye rear leafs and the two inch blocks i ordered where too much. here are a few pics and a couple of vids. does it look like its running too rich or is that just because its a new motor?
too rich? http://videos.streetfire.net/video/e0102f4b-bbf8-4a7b-8667-99f80143e912.htm
[IMG]local://upfiles/18218/821756690339421C816C0FBF30FEC2AD.jpg[/IMG]
[IMG]local://upfiles/18218/131326F45B164C5FA54E4D719ED77585.jpg[/IMG]
[IMG]local://upfiles/18218/7FF88FAACA7047B78B762F2B8A2F84E0.jpg[/IMG]
Old Dec 2, 2007 | 06:50 PM
connor90's Avatar
connor90
Default RE: almost ready!
i dont think its running too rich...looks like its just a little cold outside.
overall its lookin real good
ndnboy's Avatar
ndnboy
project is moving along, congrats.
I installed a spacer a while back, guys advised it would help with the hard starts/vapor lock issues, it has.
Old Dec 2, 2007 | 06:51 PM
eZ's Avatar
eZ
i live in so. cal. its not cold.
Old Dec 2, 2007 | 06:52 PM
connor90's Avatar
connor90
oh well in that case it does appear to be running a little rich
but im not an expert...as proved time and time again on these boards haha [8D]
Old Dec 2, 2007 | 06:57 PM
sixt5's Avatar
sixt5
heh its got a black eye
Old Dec 2, 2007 | 07:03 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
If it were running terribly rich you'd smell it and see black smoke not white[&:]to get a base line on the A/F you need it on a dyno to measure the mixture and or a o/2 sensor with a gauge...edelbrock sells a/f sensor/indicator deals!!..as for the spacer the theroy is that it raises up the carb hence giving the a/f mixture a greater/ longer distance to speed up which in turn premotes a better combination of a/f and it speeds up air velocity to help a/f reach the cylinders quicker and more efficiently.........now do they work!!?? yeah!! but a 1/2 to a 1 inch spacer .hmmmmmmmm?? probably won't be noticable seat of the pants performance[&:]
Old Dec 2, 2007 | 07:05 PM
eZ's Avatar
eZ
so do you think the white smoke is just from the motor being new? also when reved it did spew out quite a bit of moisture.
Old Dec 2, 2007 | 07:08 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
how long did u let it run let it run for a while probably have a little condensation built up in the exhaust etc a new motor is gonna smell funky and smoke a little while the rings seat
Old Dec 2, 2007 | 07:12 PM
eZ's Avatar
eZ
it has sat for almost a year. in a garage though. need to drive it down and have the tranny adjusted just right though. acts kinda funny.
