Radiator to hot
Old Dec 3, 2007 | 02:45 PM
krobillard's Avatar
krobillard
Default Radiator to hot
I have a two coral radiator, with a new cap, after driving the car for while, water will start to come out the top overflow hose.
Should I replace my stock thermorstats? not sure of the degree ( 180 or 190) and should I go with a 160 degree. Or what else could be cause the overflow?
Thanks
Old Dec 3, 2007 | 02:53 PM
krobillard's Avatar
krobillard
Default RE: Radiator to hot
Sorry, its 302/4b/auto, all recent rebuild
Old Dec 3, 2007 | 03:06 PM
jlg2002's Avatar
jlg2002
Take a look in the Top section for overheating help.
Old Dec 3, 2007 | 03:13 PM
TexasAxMan's Avatar
TexasAxMan
Add an overflow tank. Also, the 2 core (not "coral") may be a little wimpy, consider a 3 core.
Old Dec 3, 2007 | 05:01 PM
connor90's Avatar
connor90
if its running too hot they sell this stuff called water wetter, it actually works really well. you might want to look into it.
Old Dec 3, 2007 | 08:38 PM
Colorado_Mustang's Avatar
Colorado_Mustang
If you don't have an overflow tank, do not fill the radiator to the top or it will push out the overflow tube, under normal conditions. The coolant should be 3-5 inches below the top of the radiator.
Old Dec 3, 2007 | 09:52 PM
ebluekeys's Avatar
ebluekeys
I just installed a two row (15/16 inch diameter tube!!) ALL ALUMINUM direct replacement radiator. Aluminum cools 4X as well as brass tubes. Looks cool too!! Just google "67 ford aluminum radiator". There are lots of "almost fits" but this place offers the dual row for around $250 delivered. Made in china, but excellent quality, and pressure tested. I'd give you the address, but already lost the darn receipt...
Old Dec 3, 2007 | 10:13 PM
Gun Jam's Avatar
Gun Jam
If you end up replacing the radiator I also suggest a 2 core aluminum made by Northern. Its a reasonable price for the excellent quality and direct replacement.
-Gun
bradleyb
Nov 27, 2015 07:50 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
jrrhd73must
Oct 2, 2015 09:17 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
