Why solid lifters?
Old Dec 4, 2007 | 06:02 PM
Reverb's Avatar
Reverb
Default Why solid lifters?
Why would somone install solid lifters instead of hydraulic ones? Higher revs? Better response?
Old Dec 4, 2007 | 07:12 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Default RE: Why solid lifters?
Seems like you answered your own question.
Old Dec 4, 2007 | 07:18 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ther are lighter and can be revved higher
Old Dec 4, 2007 | 07:28 PM
Reverb's Avatar
Reverb
Sounds good to me.
Old Dec 4, 2007 | 07:38 PM
JamesW's Avatar
JamesW
Unless you're building a 450+HP motor... then just stay with roller lifters
Old Dec 4, 2007 | 07:42 PM
Reverb's Avatar
Reverb
ORIGINAL: JamesW
Thats what I'm planning on. Don't ask me for figures, I wont know until it's been built, but I know it's going to be putting the power down on the top half of the rev range.
Old Dec 4, 2007 | 07:45 PM
my77stang's Avatar
my77stang
a solid lift cam will make more power than a hyd. cam with identical lift and duration, but they will require more maintaining, and they will make noise.
Old Dec 4, 2007 | 09:48 PM
Scott H.'s Avatar
Scott H.
Old Dec 4, 2007 | 10:40 PM
Colorado_Mustang's Avatar
Colorado_Mustang
I only have flat tappets. My 302 didn't come with them there fancy rollers.
ORIGINAL: JamesW
I assume you mean "hydraulic lifters."
Old Dec 4, 2007 | 11:25 PM
gothand's Avatar
gothand
Had solid lifters on a cam in a 351W with 0.57" or so of lift and it ran like a bat out of hell. That said, adjusting the valves became tedious, made worse by have to deal with the the stud girdles. To make adjustment a bit less messy, I cut the top off of a set of valve covers..
Jeff
