disk brake
Old Dec 15, 2007 | 01:00 AM
xian67's Avatar
xian67
Default disk brake
So i was looking at www.diskbrakeswap.com
SWAP.2 Classic Ford Disc Brake Swap Kit This kit includes everything needed to swap out your front drum brakes for OEM style disc brakes. All new parts including a spindles kit, refurbed cardone calipers, Raybestos made semi-metallic pads, brake hoses, adjustable proportioning valve, major brand refurb master cylinder, bearings, seals, a 22 piece small parts kit, and performance slotted rotors. Note that you will need to adapt or refab your hard brake lines to accommodate the proportioning valve, the master cylinder, and the brake hoses.
only 545 dollars?
This is really all i need?
Old Dec 15, 2007 | 02:15 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: disk brake
Yep! And it's a great deal, and a great company too
Old Dec 15, 2007 | 05:25 AM
67 evil eleanor's Avatar
67 evil eleanor
Looks like a great price. Is that a adjustable proportioning valve with the kit?
Old Dec 15, 2007 | 11:04 AM
xian67's Avatar
xian67
oh damn. im buying it in then. i have 450 saved up so far ;D
Old Dec 15, 2007 | 01:50 PM
restomod@16's Avatar
restomod@16
wow thats a great buy!
Old Dec 15, 2007 | 02:20 PM
SalikDDD's Avatar
SalikDDD
yeah i bought mine a few weeks ago. - it all comes in pieces so you gotta build it all yourself but everything looks good even fi the bearings are all chinese and stuff comes with a proportioning valve 1 in 1 out, so you need to use your original combination valve but everything else is great. comes in 2 heavy *** boxes, around 110lbs total.
Old Dec 15, 2007 | 03:15 PM
musnicki's Avatar
musnicki
My vision is going but does the kit include a master cylinder? I was squinting in there and thought that I saw one….if so, I will add this to my dream list of crap to upgrade in the far future.
Old Dec 15, 2007 | 03:24 PM
Starfury's Avatar
Starfury
There is no 'combo valve' in drum brake cars. There's a distribution block, but that's not the same thing. Ideally you should get the combo valve and adjustable proportioning valve from them and plumb them both in.
Old Dec 15, 2007 | 04:00 PM
hammerit's Avatar
hammerit
No booster or do you already have one. Or are you going non power disc?
Old Dec 15, 2007 | 04:04 PM
degins's Avatar
degins
ORIGINAL: xian67
only 545 dollars?
The kit has evolved a bit since I wrote that description. The kit now has all new parts. Additionally, italso now includes an adjustable pushrod for manual brake application and a 10 lbs residual pressure valve (despite common belief, new and rebuilt MC do not have a residual pressure valve in the rear circuit). The current price is $525 + S&H.
I obviously am better at manufacturing brake systems than publishing a web page. I have had problems finding someone to build a site that meets my specification.
