frame off question
Old Dec 15, 2007 | 02:36 PM
truegraw's Avatar
truegraw
Default frame off question
whats up, im a newbie to the forum thing so bare with me. i have a 69 mach 1 and im wanting to take the body off the frame to do the real detailing i want, ive got the car pretty much stripped just wondering how hard it is to get the body off, also i wonder if me and a couple guys could lift the body without damaging the metal. any info would be appreciated!
Old Dec 15, 2007 | 02:53 PM
Starfury's Avatar
Starfury
Default RE: frame off question
Mustangs are a unibody construction. There is no separate frame, the body is the frame
Old Dec 15, 2007 | 03:28 PM
dlynch's Avatar
dlynch
unibody bro
Old Dec 15, 2007 | 04:55 PM
JMD's Avatar
JMD
Yea, it is a unibody, but you can take all of the bolt on parts off in order to doa real nice job on the details. I can't say much about a 69, but the 64 - 66 style Mustangs are a work of art based upon their udder simplicity, I imagine that a 69 is a bit more complex but still a very simple car.
Post your questions here and you will get answers!!
Since the car is a unibody, it will take more than a couple of strong men to handle the body, but, much (all) of the work can be done from under the car when properly supported. The exception might be if you have extensive rust on the bottom side of the car.
If you really want to work on the bottom you will need to get a rotisserie (<thank you spell check!)so you can turn the body at will. There are a few members here who have used them, MustangLover66 made his own killer rotisserie.
Old Dec 15, 2007 | 05:01 PM
JMD's Avatar
JMD
Oh yea.... Welcome to the Forum!!!
Old Dec 15, 2007 | 05:11 PM
truegraw's Avatar
truegraw
appreciate the info , yea i knew it was unibody but i always hear frame off resto by alot of guys? the rust isnt bad at all the floor pans need replacing i was wondering if anyones done a full floorpan install really i could get by with the front and back only (without the toe)but someone has messed up the the floor where the shifter comes through and instead of patching it i was wanting to replace it also, so if i did go with full pan would i have to weld any kinda bracing before i cut the old one out? one more question, do u think a gravity fed sand blaster would be to harsh or 2 much a mess 2 do the engine bay and undercarage?
Old Dec 15, 2007 | 05:20 PM
JMD's Avatar
JMD
ORIGINAL: truegraw
With the exception of the part about the sandblaster, the entire question is out of my league. We were able to get the car on the road without any metal replacement. There are many people here who have done full floor pan replacement.I am sure they will chime in. The sandblaster will work fine. The media that you use will determine what the effects on the car will be more than the type of sandblaster used. Be aware that even small sandblasters require lots of air for effective use. Sandblasting can be messy, probably would want to do it outside, and sweep up daily.
And yea, "frame off" is a a well used term, that is not always used in the strictest sense of the word. I think I knew what you meant.
Old Dec 15, 2007 | 05:26 PM
ky's Avatar
ky
America ftw
i replaced te pans in my stang. i ddint get the whole complete pan cause it was 500 bucks so i got the long sections on each side and then the rear sections under the rear seats.
Old Dec 15, 2007 | 06:20 PM
sschanz's Avatar
sschanz
Here's a good link on replacing the floor pans yourself. It's not hard to do if you take your time and no one will see your mig seams.
http://www.mustangmonthly.com/howto/...ace/index.html
Old Dec 15, 2007 | 10:45 PM
andrewmp6's Avatar
andrewmp6
Frame off does mean taking the body off the frame but on a unibody you do a bare shell resto.Good luck on your floor pans.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mrappe
Sep 26, 2015 10:16 AM
