rough idle
Old Dec 16, 2007 | 09:17 PM
390bigblock1's Avatar
390bigblock1
Default rough idle
i just rebuilt my carb, and it has a rough idle, could it be the timing? any help would be good
Old Dec 16, 2007 | 10:02 PM
390bigblock1
Default RE: rough idle
nvm she just need to run for a little bit and a little carb tunning got it right with a nice smooth low but high enough idle
Old Dec 16, 2007 | 10:26 PM
Scott H.'s Avatar
Scott H.
Old Dec 16, 2007 | 10:45 PM
390bigblock1
ok let me re phrase it, i replaced the main gasket on it, but the car hadnt been ran in about 4 weeks and the gas in brand new, but i got it running, good i think it was just the old gas that was still left in the lines, but the engines not stock at all and the carbs almost brand new,
Old Dec 17, 2007 | 10:31 AM
LPlum's Avatar
LPlum
Old school rule, you want to make sure the ignition system is in good shape before you go to the carb. Is a tune-up in order? Plugs, plug wires, points, condensor, cap, rotor. Then setting dwell and timing. Then carburation. The other most important factor is that the engine is in good working order, no vacuum leaks and good even compression.
Good luck,
Lowell
Old Dec 17, 2007 | 11:53 AM
69thunder's Avatar
69thunder
Did it have a rough idle before the rebuild? If it didn't there is likely a vacum leak associated with the carb like the base gasket or lines being old. Sometimes just removing an old vacum line is enough to make it leak. If it was rough before then you'll have to check ignition as well as vacum leaks.
Old Dec 17, 2007 | 01:27 PM
390bigblock1
before i rebuilt the carb it was fine it had just got back from the shop that changed the ignition, plugs and wires, and the only reason i rebuilt it was because of my stupid friend some how got paint in it and luckily it didnt get into the engine so i just took the top of to clean in out, but its all fixed its running good.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
MacSerio
Sep 27, 2015 01:05 PM
