new distributor question
Old Dec 17, 2007 | 02:40 PM
Mustangdemon67's Avatar
Mustangdemon67
Default new distributor question
so i bought a new distributor but i got to thinking if i should replace the stock gear at the bottom. because if im correct, the stock gear is made for hydraulic cam, so does that mean a roller cam will eat it up? i was looking at the msd replacement gears and they are 70$+. thats not too much but im not gona buy it if i dont need it.
Old Dec 17, 2007 | 03:33 PM
Starfury's Avatar
Starfury
Default RE: new distributor question
You're correct...mostly. The stock gear is castiron, the same material a flat tappet came is made of. A roller cam, whether or not it uses solid or hydraulic lifters, is made out of forged steel and will chew that iron gear up in short order. So yes, you do need a new gear
Old Dec 17, 2007 | 03:47 PM
mustangmatt63's Avatar
mustangmatt63
If you Do not change it you will be regretting it in a few hundred miles!! The hardened Forged Steel will destroy the old one in short order.I would definitely replace it!TRUST ME!! I MADE THAT MISTAKE LAST YEAR!![8D]
Old Dec 17, 2007 | 04:18 PM
Mustangdemon67
ok will do. it looks like the stock gear just has that little push pin holding it in. im assuming i need a punch to take it out. i dont have to worry about the new one coming loose do i? should i take it somewhere and have a bigger hole tapped?
Old Dec 17, 2007 | 05:04 PM
67mustang302's Avatar
67mustang302
Take it somewhere and have it done. The gear needs to be positioned properly so you have the correct thrust setting. Steel gear with steel cams(roller) and iron gear with iron cams(flat tappet).
GimpyHSHS
19
Dec 19, 2023 01:12 PM
bradleyb
Nov 27, 2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
treesloth
Sep 28, 2015 07:03 AM
