mini tub help
Old Dec 23, 2007 | 06:15 PM
  #21
Deviousfred's Avatar
Deviousfred
Default RE: mini tub help
on second thought, I would say don't cut the original mounting tab. Leave it in place and fabricate a new one from something line (1/4" sheet metal?) amd box it in around the back
Old Dec 23, 2007 | 06:16 PM
  #22
eZ's Avatar
eZ
you could strengthen the vack side of it by just Ting it off from the existing frame?
[IMG]local://upfiles/18218/BBAD4D0929C94F83967223617DC05362.jpg[/IMG]
Old Dec 23, 2007 | 06:18 PM
  #23
eZ's Avatar
eZ
ORIGINAL: Deviousfred
exactly...but then you are moving the front portion more than the rear portion. I think a new fuel tank would be needed to make it work.
  #24
Deviousfred
would you still be using a shackle in the rear? that might be the perfect place for slider spring mounts in the rear from Cobra Automotive
Old Dec 23, 2007 | 06:22 PM
  #25
eZ's Avatar
eZ
well im thinking that if you use a shackle in the front and then not use one in the rear. pretty much reversing the way the springs are mounted that would give you the couple of inches you need to get the tires up against the frame?
Old Dec 23, 2007 | 06:26 PM
  #26
Deviousfred
wonder what that would do to ground clearance?
Old Dec 23, 2007 | 06:27 PM
  #27
eZ's Avatar
eZ
ground clearance wouldnt be a problem. performance might be a problem though.
Old Dec 23, 2007 | 06:31 PM
  #28
Deviousfred
Yeah, I'm not too sure how that would affect handling. Good luck with the tubs.
Old Dec 23, 2007 | 06:55 PM
  #29
jcomp's Avatar
jcomp
Maybe one of the suspension experts can tell us why reversing the leaf spring mounts is a bad idea.
mungodrums
Sep 29, 2015 09:18 PM
mrappe
Sep 26, 2015 10:16 AM
Sep 8, 2015 06:25 PM
iamgobono
Sep 3, 2015 12:37 PM
