BAD vibration!
Old 12-26-2007, 05:07 PM
sixt5
sixt5's Avatar
Default BAD vibration!
well we got the 4 speed in and we have a bad vibration when running. was told that it was the wrong flywheel. all the parts came together so we didnt hesitate to put parts in without looking.
anyways, which flywheel do i need? 65 289 with a toploader (plate reads out of a 69)
sixt5 is offline
Old 12-26-2007, 06:09 PM
Gun Jam
Moderator
Gun Jam's Avatar
Default RE: BAD vibration!
sounds like maybe you got the right flywheel but put it on wrong.
did you take care to place the flywheel on in the correct angle? The balance might be 90 degrees (or something like that) off the correct location.
-Gun
Gun Jam is offline
Old 12-26-2007, 06:22 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the flywheel will only bolt on one way sure you have the proper flywheel? did you have the vibration b4 the conversion
rmodel65 is offline
Old 12-26-2007, 06:54 PM
69FECoupe
69FECoupe's Avatar
You converted from an automatic didn't you? Did you install a pilot bushing in the crank?
69FECoupe is offline
Old 12-26-2007, 06:56 PM
sixt5
sixt5's Avatar
no vibration before. we thought we had the right one but i guess its not. Yes the bushing is in there.
sixt5 is offline
Old 12-26-2007, 08:32 PM
JamesW
Moderator
JamesW's Avatar
You need a small weight, or 28oz imbalance flywheel. In the photo below, a left is a stock 28oz flywheel. On the right is the later model 50oz flywheel that has been rebalanced to 28oz. (this was done to fit a T-5 with a modern king cobra clutch)
JamesW is offline
Old 12-26-2007, 11:10 PM
onegreedy
onegreedy's Avatar
also are the 351 w a different balance, if so could be a 69 351 flywheel and not a 302!
onegreedy is offline
Old 12-26-2007, 11:34 PM
67mustang302
67mustang302's Avatar
Early 302/289 and 351's are a 28oz balance factor, 302HO's are 50.
67mustang302 is offline
Old 12-27-2007, 07:33 AM
sixt5
sixt5's Avatar
so i need a 164 tooth 28oz?
sixt5 is offline
Old 12-30-2007, 06:18 AM
lilrobo
lilrobo's Avatar
what we found was a wrong flywheel ( 50oz ) ,, so we got new one ,then we had a wrong pressure plate and a wrong disk ,, so we replaced all those,, it runs good now ,, now all we need to do is adjust the clutch he says it catches at the top , the adjuster rod is most of the way in,, is all i need to do is extend it a little and check it ???
lilrobo is offline
Quick Reply: BAD vibration!
