5.0
Old Jan 3, 2008 | 02:39 AM
JERM_1967stang's Avatar
JERM_1967stang
Default 5.0
Would a 5.0 engine with an auto trans bolt right up 2 a 67 with an original v8 under the hood. without fabing anything or cutting?
Old Jan 3, 2008 | 03:25 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: 5.0
yes you need a flexplate with a 50oz balance along with a harmonic balancer that 50oz also but with the vintage bolt pattern for your pulleys, you need to put the 5.0 dizzy gear on your vintage dizzy. and reuse you original oilpan,pickup,and timing cover,intake ands carb and you have to block off the 5.0 dipstick hole with a wooden dowel do this and youll be golden
Old Jan 3, 2008 | 03:45 AM
JERM_1967stang
Default RE: 5.0
come again. and there isnt a did method to that wooden dowle thats a lil more professional?? i understand the oil pan buissness. but y cant i just drop the entire setup in?? y do i need new pulleys and ****? whats a dizzy? and a flexplate?? also the driveshaft and all. and could i possibly convert that into a carb setup??
Old Jan 3, 2008 | 07:14 AM
Mustangdemon67's Avatar
Mustangdemon67
Default RE: 5.0
ok, heres a little run down. there is no outlet for mechanical fuel pump on the 5.0s so you need to run an electric pump. gona need a new flywheel. gona need a new oil pan, you can use your 289 distributor but you should change the gear on it. you can use your old 289 pulleys and run a v belt system or if your up for it you can go serpentine belt system. your going to need to drill a hole for the dipstick. if you dont have ac,power steering and smog then a serpentine belt is going to be a little tricky to hook up. and yes you can carb the motor, just take off the efi intake and put on yours then the carb. as for the C4 and driveshaft and all that its fine. you might want to look into a new stall converter too.
Old Jan 3, 2008 | 09:54 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: 5.0
ok, both of those are right, but i dont think they answered your question.
yes you can drop a 5.0 into the 289 mounts, same block diffrent stroke, and you wont need to fab anything up.
next question... do you have the complete 5.0 setup? if so then dont worry about the other stuff posted above, if your building just build a normal 5.0 and put it in.
Old Jan 3, 2008 | 09:04 PM
JERM_1967stang
Default RE: 5.0
ORIGINAL: USMCrebel
+1 thats what im saying. And what auto trans came with the 5.0? and do i need a new drive shaft or what??
Old Jan 3, 2008 | 11:33 PM
JERM_1967stang
Default RE: 5.0
umm do i need a new shaft or will the stock one work??
Old Jan 3, 2008 | 11:40 PM
1970coupe's Avatar
1970coupe
Default RE: 5.0
wow how many posts have you made for this 5.0 question? 3-4? you need to post the questions on one topic about the same thing.
i wish i could help you tho on the question but i dont know jack crap about 5.0s
Old Jan 3, 2008 | 11:43 PM
JERM_1967stang
Default RE: 5.0
lol well i have diff questions to ask and it seems like everyone has a convo started in the others then the original question isnt fully answered
Old Jan 4, 2008 | 12:14 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: 5.0
it will be answered in time be patient were here[8D]
