1965 Coupe block question
Old Jan 3, 2008 | 02:24 PM
dan0880's Avatar
dan0880
Default 1965 Coupe block question
Does anyone have a list of blocks that will fit in a 1965 coupe with only changing the mounts and suspension.
Old Jan 3, 2008 | 02:38 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: 1965 Coupe block question
v8's
289
302
Old Jan 3, 2008 | 02:42 PM
dodgestang's Avatar
dodgestang
170
200
250
260
289
302
351w
351c
Old Jan 3, 2008 | 02:43 PM
dan0880's Avatar
dan0880
What about a 351w?
Old Jan 3, 2008 | 02:44 PM
dan0880's Avatar
dan0880
The 351c will fit with no mods?
Old Jan 3, 2008 | 02:45 PM
USMCrebel's Avatar
USMCrebel
would the 351 deck height be to much? he'd have to change his hood right.
Old Jan 3, 2008 | 02:48 PM
dodgestang's Avatar
dodgestang
Yes the 351c fits no mods
No you don't have to change the hood to run either the 351c or 351w.
The w is a very common swap you just can't run a tall intake, you run a mid to low intake and a drop base air cleaner. The c is a less common swap but still a bolt in with the correct mounts and headers and will also fit under the stock hood with a low to mid rise intake and a drop base air cleaner
dan0880's Avatar
dan0880
I was thinking the same thing
Old Jan 3, 2008 | 02:49 PM
dan0880's Avatar
dan0880
Thanks guys for the info and help
Old Jan 3, 2008 | 03:25 PM
USMCrebel's Avatar
USMCrebel
ORIGINAL: dodgestang
ok thats why i was thinking it wouldnt fit, everyone around here runs the taller intakes on them, and i've never seen a 351 in a 65-66
