Weights
Old Jan 3, 2008 | 03:37 PM
Obituaries's Avatar
Obituaries
Default Weights
Was curious If someone has a list of the stock curb weights for 64 1/2-73 Mustang coupes, fastbacks and sportroofs. Any info is greatly appreciated and thanks in advance.
Old Jan 3, 2008 | 04:08 PM
cmanf's Avatar
cmanf
Default RE: Weights
Gota love wickapeida
http://en.wikipedia.org/wiki/Ford_Mustang
Old Jan 3, 2008 | 04:22 PM
Obituaries's Avatar
Obituaries
Default RE: Weights
Yea, I see a reason to love it now too. Thanks that pretty much wraps that up.
Old Jan 3, 2008 | 04:57 PM
fordification's Avatar
fordification
Default RE: Weights
When they say "(V8)", would thatbe the biggest, smallest or midway?
Curb weight
2570lb (1170kg) (six-cylinder)
3000lb (1360kg) (V8)
Old Jan 3, 2008 | 07:11 PM
cmanf's Avatar
cmanf
Default RE: Weights
Im guessing big block.
Everything ive looked @ other places say 2800lbs 289 auto 1966.
Guess ill weigh mine one day. I added a roll cage and sub frame connectors.
LOL guess going to alu. heads got offset by the paxton tho then there is the 5 speed over the 4 speed.
Fuell cell over stock tank.
My guess is 300lbs for mine then add 250lbs for my fat butt!
Old Jan 3, 2008 | 07:22 PM
eZ's Avatar
eZ
Default RE: Weights
5.0 weigh the same as the 289? my car started out as a inline 6 at 2500 lbs. with the AOD, 9' and 5.0 its probably around 3000 to 3200 i would guess.
Old Jan 3, 2008 | 07:52 PM
cmanf's Avatar
cmanf
Default RE: Weights
My guess it should weigh about the same as 289 same size and components.
The forged pistons more / less? cant be that much if any.
Old Jan 4, 2008 | 09:00 AM
fordification
Default RE: Weights
how hard would it be to keep a 68 coupe 390 around 2800? think it could be difficult. especially with a roll cage and sub frame like cmanf mentioned.
Old Jan 4, 2008 | 09:08 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Weights
ORIGINAL: fordification
wont happen, lets say its at least 635, the chasis weight is let for ****s and giggles say 2000lbs already your at 2635, thats without the tranny probably about 100-120 lounds now 2755, 50lbs of roll cage 2805, now you lets lsay 200lbs= 3000lbs, you can get fairly close, but big blocks are heavy as hell, but the tq makes up for that
Ford flathead V8 525 (124) 1932 model, integral b'hsg, iron heads
Ford flathead V8 569 (1) ('53 239 CID)
Ford Cosworth DFV 353 (2) (racing engine, DOHC, 3.0L)
Ford 255 Windsor 468 (4)
Ford 289/302 V8 460 (168) (late 5.0s are a bit lighter)
Ford 221-302W 460 (48)
Ford Indy 255 pushrod 360 (120) all aluminum, 1963
Ford Indy 255 DOHC 400 (120) 1964, later known as Foyt Coyote V8
Ford 5.0 V8 450 (109)
Ford 5.0 V8 411 (171) 89 Mustang 5.0 GT (dry) inc: manifold,
carb(?), headers and alternator. Not
inc: starter, smog pump, power steering
pump, AC compressor, flywheel
Ford BOSS 302 500 (48)
Ford 351 Cleveland 550 (48) (includes BOSS and Australian 302-C)
Ford 351 Windsor 510
Ford 351 Windsor 525 (48) (168)
Ford 351M-400 575 (48)
Ford Y block V8 625 (272-312 CID)
Ford FE big block 650 (332-428 CID)
Ford FE big block 670 (1) ('59 352 CID)
Ford FE 625 (48)
Ford 427 SOHC 680 (48)
Ford 429/460 V8 640
Ford 429-460 720 (48)
Ford 460 V8 720 (10)
Ford BOSS 429 680 (iron block, aluminum heads)
Ford BOSS 429 635 (48)
Ford 4.6 SOHC 530 (93) iron block, aluminum heads
Ford 4.6 SOHC 473 (72)
Ford 4.6 SOHC 600 (168) (Mustang)
Ford 4.6 DOHC 464 (72) "9 pounds lighter than SOHC"
Ford 4.6 DOHC 437 (77) without accessories
Ford 4.6 DOHC 521 (94) aluminum block and heads
Ford 4.6 DOHC 576 (168) (Mustang)
Ford Triton V10 635 (128) "dressed"
Old Jan 4, 2008 | 09:32 AM
Norm Peterson's Avatar
Norm Peterson
Default RE: Weights
A little bit off-topic, but you might want to add the 3-valve 4.6 (similar to the S197 GT) at 420 lbs dressed (whatever that means). See page 94 in the current FRPP online catalog.
Norm
