help please
Old Jan 4, 2008 | 07:09 AM
slick66stang's Avatar
slick66stang
Default help please
all my spark plugs were so loose i didnt need the socket to take them out. my problem is my car is making a odd popping noise and acts like shes going to die. im thinking its my distrubitor, what do u guys think?
Old Jan 4, 2008 | 07:11 AM
blue66mustang's Avatar
blue66mustang
Default RE: help please
After you tightened the plugsdid you getthe wiresback in the rightorder ??
Adrenolin's Avatar
Adrenolin
Use the socket to tighten the plugs? lol sorry couldn't resist that.[sm=icon_rofl.gif]
Old Jan 4, 2008 | 07:18 AM
mustangmatt63's Avatar
mustangmatt63
Sounds like you have some plug wires wrong after you tightened the plugs(I am assuming you did).If all your plug wires are right check your timing!![8D]
Old Jan 4, 2008 | 07:35 AM
bluovalguy's Avatar
bluovalguy
ORIGINAL: Adrenolin
I had an old ford truck and one of the plugs worked itself loose. Made a bunch of popping sounds also. Then the plug backed all the way out, and it was REALLY LOUD popping sounds and ran like ****.
Old Jan 4, 2008 | 09:14 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
+1 to what everyone said, sound like a back fire as well so check the points and condenser and make sure they're gapped properly
Old Jan 4, 2008 | 08:51 PM
slick66stang
thanks everyone. i figured it out, my points were gapped to far apart, the plugs were gauged to far apart, and the wire in my distrubtor was grounding itself out and my timing was off a little bit
Old Jan 4, 2008 | 08:58 PM
mustangmatt63
Glad to hear you figured it out!![8D]
Old Jan 4, 2008 | 09:14 PM
slick66stang
me too, it is way to cold to be working at night on my car with wet clothes on.
im going to wrap that wire in a rubber hose tomorrow
