Trunk mount battery- Opinions needed!
Old Jan 8, 2008 | 03:34 PM
john721's Avatar
john721
Default Trunk mount battery- Opinions needed!
I am going to mount the battery in the trunk of my 65 fastback. Which battery would you guys recommend I use?
Old Jan 8, 2008 | 03:53 PM
urban_cowboy's Avatar
urban_cowboy
Default RE: Trunk mount battery- Opinions needed!
I love my Optima! There are several power levels. I bought the big one to keep things lit up hot!
Old Jan 8, 2008 | 04:03 PM
Starfury's Avatar
Starfury
There are only a couple sizes, the larger sizes having more power. A 34/78 is the largest car battery size available and will work fine.
There are different types of Optimas for different applications. If your car is a daily driver with no huge loads on the electrical system (ie. stereo and large amp), a Red Top will work fine. If your car tends to sit for a while, or if you have a high powered audio system in it, a Yellow Top will be better suited to those conditions.
I have a Red Top in my daily driver and it works great. Starts every time, has plenty of reserve for continued cranking, and it's already about 4 years old.
Old Jan 8, 2008 | 04:07 PM
john721's Avatar
john721
thanks guys... it will be a daily driver... once again..sound advice. Thanks a bunch!
Old Jan 8, 2008 | 04:14 PM
66FastbackGT_T5's Avatar
66FastbackGT_T5
Hi!
I will mount my Battery in the trunk, too.
And for the wiring to my Starter i use welding-Cable froma Ship-Wharf. Its cheap, has dozen of lines inside and is very soft to handle
Old Jan 8, 2008 | 05:05 PM
jlp66stang's Avatar
jlp66stang
How are you thinking of routing the cables?
Old Jan 8, 2008 | 05:15 PM
Mach101's Avatar
Mach101
i opted for a Optima Red, but just the normal size. Works great.
Old Jan 8, 2008 | 05:29 PM
66FastbackGT_T5
Hi!
3 Ways: Inside the car, its hard when you use very fat cables
Inside the side-rocke pannel: My way, most work, but nothing to see
Under the car: Easiest way, when you get welding cable its ready to use oudside
Old Jan 8, 2008 | 05:47 PM
JamesW's Avatar
JamesW
http://www.midnightdsigns.com/Mustang/Battery.htm
Old Jan 8, 2008 | 06:12 PM
jlp66stang's Avatar
jlp66stang
JamesW, that looks like the way to go. I couldn't tell exactly where you ran the vent tube, bottom of fender wells!
