idle RMP's
What should I set my idle to. I have a 289 manual with a agressive cam. It was set to 800. I installed a vintage AIR a/c kit in it. The A/C man set the idle to almost 1000. It drips down when the A/C is running but when it is off and the choke is open it is almost 1000. I think it is too high. Should I set the idle speed with the A/C running or off and what should it be?
RE: idle RMP's
I'd set it as low as you can get it with the engine at operting temp and the a/c on.
RE: idle RMP's
Mine is set to 750 with AC on and about 950-1000 with AC off. Much less and it stalls with the AC on, but that is going to be different for every engine depending on the cam specs and carb size.
RE: idle RMP's
Might be able to adapt a later model A/C solenoid to open the throttle a little when the a/c compressor is running....
Something I might need to consider for the 66 once I get the a/c up and running. |
RE: idle RMP's
I was thinking about getting the a/c solenoid. I guess I will have to leave the idle where it is until I get the solenoid. Its about 750-800 with the a/c on now.
RE: idle RMP's
does anyone know where i can get the a/c solenoid for an edelbrock carb?
RE: idle RMP's
http://www.edelbrock.com/automotive_...hun_perf.shtml
go down untin you see idle compensator kit. im guessing thats what you want |
RE: idle RMP's
I am not familar with the A/C solenoid...What does it do? I assume itopens the throttle some when theA/C is on...?
RE: idle RMP's
ORIGINAL: urban_cowboy I am not familar with the A/C solenoid...What does it do? I assume itopens the throttle some when theA/C is on...? |
RE: idle RMP's
I found one for my Holley 4150, but do not see one for Edelbrock carbs.
| All times are GMT -5. The time now is 01:55 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
