shift light
Old Jan 13, 2008 | 06:32 PM
slick66stang's Avatar
slick66stang
Default shift light
my shifter light in my floor isnt working, i changed the bulb and have power running to it. how can i get this to work again and does anyone have a picture of this
Old Jan 13, 2008 | 06:42 PM
jlp66stang's Avatar
jlp66stang
Default RE: shift light
When you say you have power, is that with a test light. There are two wires going to that, check your ground!
Old Jan 13, 2008 | 07:05 PM
BULLITT GT 390's Avatar
BULLITT GT 390
I don't use one myself I shift by earbut his right check you'r ground!!
Old Jan 13, 2008 | 07:49 PM
jlp66stang's Avatar
jlp66stang
I assumed he was talking about the auto shift selector.
Old Jan 13, 2008 | 08:15 PM
Gun Jam's Avatar
Gun Jam
If your using a volt meter to test for power and your getting 12v but the light doesnt light up it could be
1) incorrect (poor fit) or burnt out light
2) The ground could be very weak...its good enought to light up the low resistance digital volt meter but is unable to supply enough current to light up the light because of the bottle neck cause by a bad ground.
Gun
Old Jan 13, 2008 | 09:10 PM
mustangmatt63's Avatar
mustangmatt63
Check your ground and clean the inside of the bulb socket to make sure you have a good contact connection.Good Luck with it!!
Old Jan 14, 2008 | 07:18 AM
slick66stang
does anyone have a pic of the light assembly? im looking at pictures in catalogs and mine looks different
Old Jan 14, 2008 | 09:03 AM
jlp66stang's Avatar
jlp66stang
I don't see a pic in mine for a 66 either. What is wrong with yours?
Old Jan 14, 2008 | 05:31 PM
ninteen66mustang's Avatar
ninteen66mustang
I dont have a pic but I will describe mine and see if it helps.
It mounts to the side of the shift lever (under the bezel, of course) and it is just 2 wires running to a metal tube with a really tiny hole in the top that shines on the bezel. That tube is clipped to the shift lever with a 2 sided clippy thingy.
Old Jan 14, 2008 | 07:20 PM
slick66stang
thats what mine looks like but the tiny little hole at the top looks to be broken
