Questions for the experts!!
Old Jan 15, 2008 | 08:40 PM
66 FastBach's Avatar
66 FastBach
Default Questions for the experts!!
Hi All. Just Bought a 66 Fastback with a 302 a few week ago and have some questions. the 20yr old kid i bought it from must have never opened the hood(very dirty with little leaks) the car is in great shape. the interior is all new and redone in leather,air conditioning,new paint,new t-5 tranny,rack and pinion steering,power steering,power brakes(disc front). i noticed a little leak at the water inlet at the top of the timing chain cover, how hard to do myself?? thanx
Old Jan 15, 2008 | 08:47 PM
JMD's Avatar
JMD
Default RE: Questions for the experts!!
Sounds like you got a great car! Congrats on your purchase!
I am not sure just where you are saying the leak is... If it at the thermostat housing it is an easy fix, if it is leaking at the timing cover water pump joint still easy but a little harder.
If leaking where the timing cover meets the block, it is harder, even out of the "easy" category.. but still not that bad. The worst part of this fix is that the harmonic balancer will have to come off..
<<BTW,,, good choice for your thread title.... "Questions for the experts!!"
This will ensure that all of us with big heads will address your post...>>
Oh yea,,, duh... Welcome to the forum!!
Old Jan 15, 2008 | 08:48 PM
BULLITT GT 390's Avatar
BULLITT GT 390
is it leaking at the THERMOSTAT HOUSING or the timing chain cover?
Old Jan 15, 2008 | 08:50 PM
BULLITT GT 390
wecome.... post some photos of you'r car.....
Old Jan 15, 2008 | 08:51 PM
66 FastBach
its leaking at the inlet behind the water pump below the thermostat housing. does the oil pan come into play when replacing the timing cover??
Old Jan 15, 2008 | 08:54 PM
BULLITT GT 390
yes and it's not a EZ job to do
Old Jan 15, 2008 | 08:55 PM
BULLITT GT 390
well then it sounds like it's the timing chain cover then!
Old Jan 15, 2008 | 08:56 PM
dodgestang's Avatar
dodgestang
Have you tried simply retorqing bolts. Sometimes in the cold weather shift it can induce a little leak here and there and a simple trist on the rachet can sometimes fix the problem.
66 FastBach
tried to load some pics but it says the file is to large!! i'm not real good with computers. if someone can host my pics i can send.
Old Jan 15, 2008 | 09:03 PM
BULLITT GT 390
how big is the leak?mine has a littil leak at the top toandit's no big deal right now! I will fit it wen I put in the cam!
