4 to 5 lug conversion adaptors
Old Jan 20, 2008 | 10:26 PM
mandalore05's Avatar
mandalore05
Default 4 to 5 lug conversion adaptors
i saw thesealuminumadaptors that go on a 4 lug that supposedly will connvert it so you can put on 5 lug wheels. Does this work and is it worth it?
Old Jan 20, 2008 | 10:46 PM
connor90's Avatar
connor90
Default RE: 4 to 5 lug conversion adaptors
they work but some people say they are not safe and it is hard to find a tire shop that will work on your car after you have them on there. im running adapter style spacers on my car in order to fit the late model wheels im running and have not had any issues with them so far. they will also change the offset needed depending on how thick they are so keep that in mind when shopping for new wheels.
Old Jan 20, 2008 | 10:47 PM
1slow67's Avatar
1slow67
ROTM Moderator
I would like to know the answer of this 1 also.
Old Jan 20, 2008 | 10:52 PM
andrewmp6's Avatar
andrewmp6
What i have seen hard driving hard braking and hard cornering can and will sheer your lugs off so you can lose a wheel thats never good.The kids here like the 13 inch wire rims and they use spacers so they stick out about a foot or two and wonder why there ball joints bust lol.Just the way i look at it most wheel companys will make you rims in any back spacing and lug pattern its not cheap but work it to me.Also something to think about the heavier the wheel the bigger brakes are needed to stop that rotating mass do you trust your small drums to stop a 17 inch rim.
Old Jan 20, 2008 | 10:59 PM
mandalore05
well i just want to put on some 14 inch or 15 inch cragers on her does that make a difference?
Old Jan 20, 2008 | 11:07 PM
andrewmp6's Avatar
andrewmp6
The weight wont be much more but i still wouldn't trust wheel adapters.
Old Jan 21, 2008 | 07:55 AM
dodgestang's Avatar
dodgestang
ORIGINAL: mandalore05
Yes because as stated earlier, using these adaptors increases your backspacing requirements for the wheels to fit the car. The classic cragars will all have the back spacing for fitting the car with a standard lug setup.
If the classic cragar came as say 14x7 with 4.25 inch backspacing and you add a 1 inch think adaptor so you can go from 4 to 5 lug, to get the a 14x7 wheel to fit the same way it will need 5.25 inch backspacing.
Old Jan 21, 2008 | 02:27 PM
mandalore05
thanks for all the info
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
Oct 7, 2015 07:02 PM
DCole24
Sep 11, 2015 10:50 AM
