valve cover gasket
the rubber ones with the metal bushings in the bolt holes so you cant overtighten.
im cheap though, so i use cork with weatherstripping adhesive on one side so it doesnt slip, and permatex on the other side so it doesnt leak.
every one i have ever done like that has NEVER leaked
I like the rubber ones because you can actually reuse them. The cork ones do seal better, although I use RTV on the valve cover side just to hold it in placeand nothing on the other side.
I prefer to use the rubber ones because they can be reused but its a matter of opinion!!The cork ones work fine with some RTV!Good Luck!
[IMG]local://upfiles/72436/A6094D57FBF142D0A4B92782C98A9641.jpg[/IMG]
Anyone have a link where these nice rubber gaskets can be found?
Also, does anyone know of a place that sells aluminum valve cover spacers? I guess I would need 2 sets of gaskets then. I have my valve covers double gasketed right now (right on top of each other) and it isnt the best set up. My cobra covers just barely touch the valves...
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
