look at this 302
Old Jan 27, 2008 | 07:04 PM
my77stang's Avatar
my77stang
Default RE: look at this 302
yes, very very very similar results.
keep in mind they used the ford roller cam in that swap. you NEED a better cam, the stock flat tappets were so weak in the ***** dept.
Old Jan 27, 2008 | 07:44 PM
cprstreetmachines's Avatar
cprstreetmachines
based on my experience with ebay crate engines is that they are off ebay. If you get this and something isn't right or say it has a tick who gets to be the one to fix it, who pays for the labor to remove it if it needs to come out? How tough is it going to be when and if the problem needs to be fixed and needs to be shipped back.
think about it[sm=insomnia.gif]
Old Jan 27, 2008 | 08:00 PM
67mustang302's Avatar
67mustang302
Not only that, but I do NOT see them getting 420/430 from a 302 with TFS TW heads and cam. Most of the 9.5:1 setups running those heads and a TFS cam are making like 270rwhp, which is maybe 350 at the crank. 420/430 if they dyno'd it on 75 of nitrous, or with no accessories in a pressurized room.A 347, yeah, maybe a 331, but not a 302.
[sm=bs.gif]
LCC's Avatar
LCC
ORIGINAL: cprstreetmachines
X2
I'm sure if you shop around at local shops they will build you one for almost the same price with better parts...
Old Jan 27, 2008 | 08:48 PM
eZ's Avatar
eZ
+2 CPR actually works for a great engine builder. look them up www.tandlengines.com. I would be too scared to buy from ebay. plus T&L will send you a dyno sheet of your engine to you!
mustanglover66's Avatar
mustanglover66
I would pass on that engine The engine may have problems even they don't know about this engine up for auction has never run but is the same combination I also don't see anything about a warranty. Take a look at these engine every engine is dynoed and warrantried and as I think everyone knows I do work there machining blocks.
http://tandlengines.com/ford_index.html
Galactic
Apr 29, 2019 02:56 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
69Volunteer
Sep 30, 2015 10:39 AM
jaiidutch
Sep 14, 2015 10:29 AM
