Can someone help me
Old Mar 27, 2005 | 01:44 AM
fireman255's Avatar
fireman255
Default Can someone help me
I am trying to get in to a mustang. This will be my 1st mustang. it is a 1965 Coupe A- code I believe with a 289 and automatic. It is not perfect. It has a number of spots and scratches in it's origional paint that have what appearts to be minor rust in them. It seems to need some front end work. It runs good. It also needs some upholstery work as well as a new dash as the origional has a crack. 67,287 or 167,287 miles I am not sure.
Can someone tell me what a reasonable price for this car would be???
Old Mar 27, 2005 | 02:23 AM
Wessy's Avatar
Wessy
Default RE: Can someone help me
make a low offer like $1500 and let them decide how much you should pay. I would prolly pay no more than 4k for it.
Old Mar 27, 2005 | 12:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
If it has an "A" code engine it will have a 4 barrel carb on it. Nice engine. Paint and interior wii cost you about 5 grand. There's no telling what the front suspension is going to run you without knowing what needs replacing.
Old Mar 27, 2005 | 12:57 PM
Dan66's Avatar
Dan66
ORIGINAL: fireman255
...it's origional paint that have what appearts to be minor rust in them. (sic)
Keep in mind: a small patch of rust that you can see easily has worked its way through from a huge patch on the back side of that panel.
Old Mar 27, 2005 | 01:21 PM
fireman255's Avatar
fireman255
I agree. is the rust issue something a body shop can fix or am I better off getting a new pannel if needed prior to painting, and how much do you two think a max price I should pay is?
Old Mar 27, 2005 | 05:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
Fireman, I had a minimum amount of rust on my 65 when I bought it. It is a west Texas car. I didn't have to replace any fenders or panels. Instead, the shop cut out the rusted metal and replaced with new metal patches. However, they took the fenders, doors and trunk lid off when they prepped and painted it. The cost to me was $5,000. Now, I know there are shops that will do the job for less money, but I will never have to do mine again, because it was done right the first time. You pay for what you get with a paint job. Believe me, it is a whole lot more than just paint.
Old Mar 27, 2005 | 05:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
As far as a max price, I would say anywhere between 5 and 6 K, but that would be a retail price. He'll most likely take around 3-4 K
Old Mar 27, 2005 | 07:30 PM
fireman255's Avatar
fireman255
Thanks, That helps a lot. I just want to make sure that I am not going to be paying too much
Old Mar 27, 2005 | 07:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
No problem. First, ask them what is their bottom dollar, then negotiate from there.
Old Mar 29, 2005 | 01:47 AM
fireman255's Avatar
fireman255
Hello again,
I got my mustang. It was actually a 66' with 289. It is straight as can be and the area's of rust are only surface. I got it for 3,500 I found paper work in the dash from a 1999 sale of the car from a classic ecar lot for 4,500 and another reciept from a year ago of a 1,400 tranny rebuild. So I don't think I did too bad for my 1st.
