Retrotekspeed BOSSEFI...
Hello all, I am new to this place...
Almost ready to pull the trigger and order a kit from these guys.
Anyone have any experience with this setup?
Its going on my 69 Mach1 with a 351C 2V...
here is the link
http://www.retrotekspeed.com/product...el-system.html
Thanks...Kevin
here is the link
Thanks...Kevin
I asked this same question a little while ago. The thread below contains the answers I got.
https://mustangforums.com/m_4192827/tm.htm
I havea speed density system (Accel DFI Gen 7) running and love it. The Retrotek system is about half the cost of what I spent. It states it comes with a fuel pump and UEGO which is a great help,and will save some money. Also the fact it can alter the pump voltage will be a plus as it should run a returnless fuel system (<500hp). Look to spend a couple hundred or more if you have to buy AN fittings, filtersand hose. I think you will have to sump the stock tank or use a fuel cell and a vented cap, or vent. In looking thru their instructions, it looks to be simple and straight foward, and the ability to connect to a MSD 6A solves a lot of problems. The VE tables are self adjusting and it can run in closed loop. The only other thing that I would ask about is the fan control and A/C request input (ups theidle and turns a fan on with the A/C). Itmay have them but I didn't see it. Other than that, if it preforms likestated, then it should be a great system.Sorry for not having any direct experience with this system, but after reading this, I would like to try one myself. Let us know how it turns out.
looks pretty hot. i had a holley pro-jection 4Di 4bbl setup that i was going to use in the II. i SHOULD have used it, but i got lazy and decided it was more trouble than its worth. i had every single part for it, including upgraded chip and aftermarket software, as well as a old laptop to run the software. sold the WHOLE thing brand new for 1000 bucks on ebay[:@]
