suspension/ frame questions.
Old Jan 30, 2008 | 07:55 PM
gibsonxplayer88's Avatar
gibsonxplayer88
Default suspension/ frame questions.
my 67' has got around 120,000 on the original frame and suspension so im thinking about redoing all of the suspension, and then i wanted to know if there is anything i should do with the frame since its had a lot of use out of it.
Old Jan 30, 2008 | 08:48 PM
andrewmp6's Avatar
andrewmp6
Default RE: suspension/ frame questions.
Check for rust if you find any fix it also subframe connectors help alot and stiff the car up so does a monte carlo bar and export brace.Suspension http://www.opentrackerracingproducts.com/products/ is the same design as whats on the car just built alot better or you can go coil overs any ideas on how your gonna do the rear.
Old Jan 30, 2008 | 11:53 PM
gibsonxplayer88
im not sure yet, i think i might just replace whats in there with something that will give me a more agressive ride, i want to try and do as little as possible for the fact that i dont know what im doing on half of this so i want to keep it simple.
Old Jan 31, 2008 | 01:23 AM
andrewmp6's Avatar
andrewmp6
Good springs shocks maybe a rear sway bar your good to go it all depends on you want a smooth ride or handle like its on rails.The export brace and monte carlo bar are the cheapest things to add they stiffen up the front end a lot.
Old Jan 31, 2008 | 08:40 AM
mortman's Avatar
mortman
Check your upper control arms, check to see if the connecting tubes have worn out the arm also all bushings, ball joints and sagging rear springs, if they have never been replaced you might be in for a rebuilding experience. If you have to go that far you might want to consider front disks.
Good luck and have fun
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
treesloth
Sep 28, 2015 07:03 AM
mrappe
Sep 26, 2015 10:16 AM
tmdm
Sep 18, 2015 03:10 PM
