Engine problem
Old Feb 1, 2008 | 03:13 PM
3eleven's Avatar
3eleven
Default Engine problem
When I got my 69 coupe, the guy said the head gasket was bad but I never saw a leak. well, while trying to figure out why it was running rough, I noticed that a rocker arm was completely loose leave one valve not functioning. Well I bolted the rocker arm back into place and torqued it down. The car ran like a top after that but I found the coolant leak. However it seemed to be coming from the water pump area. Any clue if this is really a head gasket problem or am I now looking for cracked heads or block? I am looking to get the heads magnafluxed but not sure how to check the block for a crack. The compression on all of the cylinders are very good and within 5% of each other.
Thanks!
edit: it is a 302- D4DE-6015 with E5AE heads.
Old Feb 1, 2008 | 03:19 PM
TexasAxMan's Avatar
TexasAxMan
Default RE: Engine problem
Sounds like you got lucky.
Check the radiator while running (open with it cool though). If you see bubbles in the system, you likely have a bad head gasket or cracked head or block (I'd bet on the gasket though). If your compression is that close, I'm guessing you have no problem other than a leaky water pump gasket.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
