smoking a lot...
i put a new vacuum modulator in my 67 mustang and put tranny fluid in it. i accidently put a bit too much and instead of going up to the line that says full its a bit past it and goes up to the u in full...that probably isn't that much over that it's a big deal is it? also since i put tranny fluid it in its smoking a lot of white smoke that smells a bit sweet outta the tail pipes...what can be burning?
yes i checked it with the car running, and after it warms up it starts to smoke. i thought maybe i had a blown head gasket but the car hasnt been driven in a long time so i dont think i have a coolant leak, and when i did an oil change the oil was like black and my friend told me it would look milky if i had a blown head gasket. but like i said after it warms up it is a bit past full on the dipstick. that could be the problem?
One way to check the head gasket is to take the cap off the radiator and run the car until the thermostat opens. If you see bubbles, you have a head gasket problem. Generally white smoke means you are burning coolant.
"and it cant be the modulator i just put this one in the other day"
Famous last words. Unfortunatly there are planty of defective parts right out of the box.
Your post makes the smoking and tranny work sound related.
Jan 21, 2016 01:30 PM
fastbackford351
Sep 12, 2015 09:42 AM
