good welder?
Old Feb 11, 2008 | 09:14 PM
  #21
racin66coupe's Avatar
racin66coupe
Default RE: good welder?
the 3200?
Old Feb 11, 2008 | 09:19 PM
  #22
r7jbodyshop's Avatar
r7jbodyshop
yes.(3200) Not a bad price. Be sure to get gas when you start welding on the body.
Old Feb 11, 2008 | 09:22 PM
  #23
racin66coupe
i definatly will but until then-prob summer, ill just stay flux. now just gotta save up! lol
Old Feb 12, 2008 | 12:07 AM
  #24
gothand's Avatar
gothand
ORIGINAL: racin66coupe
you know, i got to thinking, and i dont think that roll cage steel is 1/2in thick. about how thick is it on average? (i realize it can be different but on average)
My Jeep cage was fabbed out of .120" wall tubing which is typical for that application. 1/2" tubing is pretty thick stuff, usually only found on heavy duty sized axle tubes.
i dont have 220v also
If you have an electric dryer outlet, you can plug your welder into it. Go to Lowes and pick up some heavy gauge outdoor wire (rubber shield, rolls-up nicely) and the appropriate plug ends and you're good to go.
NEVERMIND ABT THE 1ST ONE I WAS LOOKIN AT, I LOOKED AGAIN AND IT TOO CAN ONLY WELD 5/16
You'll never come close to welding anything that thick on your Mustang, and even if you needed to, it wouldn't be with a 110V welder.
Good luck!
Jeff
Old Feb 12, 2008 | 10:23 AM
  #25
silverblue66's Avatar
silverblue66
"the best welder is the one holding the gun" or "a poor craftsman blames his tools"
seriously. im not saying that different welders are not better or worse depending on what you use them on. but a torch would weld a rollcage/exhaust/body panels/etc. a good 110 volt mig is great for the home welder, should work fine. you dont really need anything that can weld 1/2 thick plate steel unless you are building a skyscraper in your backyard, or are doing some major fab work. my point is that any of these welders are fine butyou must learn to be a good welder in order to make good welds.i prefer mig myself. good luck.
Kip
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
ctgreddy
Sep 20, 2015 08:35 PM
Sparks_88
Sep 8, 2015 01:06 PM
