adjustable strut rod/lower control arm question
Old Feb 12, 2008 | 05:08 PM
supraman408's Avatar
supraman408
Default adjustable strut rod/lower control arm question
i have a 67 mustang and looking to get adjustable strut rods for. i wanted to know if the ron morris performance adjustable strut rod requires the 68 lower control arms or if they are compatible with 67 lower control arms. from what ive seen at opentracker and rosehill performance parts, adjustable strut rods for 67 mustangs do require 68 lower control arms, i dont know if the ron morris ones are different because they did not mention it on their (ron morris) page.
has anyone bought adjustable strut rods from any of these providers? which one did you go with and are you happy with the results. im looking at strut rods from three different providers and cant decide.
Rosehill Performance Parts: $230
http://www.rosehillperformanceparts.com/
Ron Morris Performance: $299
http://www.ronmorrisperformance.com/...ode=Susp_Parts
Opentracker Racing Products: $369
http://www.opentrackerracingproducts.com/strutrod/
Old Feb 12, 2008 | 05:45 PM
baddog671's Avatar
baddog671
Default RE: adjustable strut rod/lower control arm question
strut rods for 67's are unique in that they only work for 67, not any other year. I wonder if they require 68 LCA's for a 67 so they dont have to make a separate model that has such a limited market?
Im partial to Opentracker, even though its moe expensive..
Old Feb 12, 2008 | 05:55 PM
zmetalmilitia's Avatar
zmetalmilitia
check out streetortrack.com for adjustable strut rods
Old Feb 12, 2008 | 07:36 PM
67mustang302's Avatar
67mustang302
The factory strut rods on 67's are already adjustable. The aftermarket ones are a bit easier to adjust, but the factory ones will adjust just as well. That's what those 2 big nuts on each rod are on either side of the bushings.
Old Feb 12, 2008 | 09:17 PM
baddog671's Avatar
baddog671
ORIGINAL: 67mustang302
I think the theory on theaftermarket ones is thatthey dont rely on a rubber bushing. The rubberflexes and therefor changes the geometry but the aftermarkets dontdo that, so it is always correct....or so thats what i've heard..
Old Feb 12, 2008 | 09:19 PM
Daze's Avatar
Daze
yes that is absolutely correct but the main advantage of "adjustable strut rods" is not the adjustability, it is the free moving pivot. By eliminating the bushings you free up suspension and improve handling and that is the reason to upgrade. Being able to easily adjust them is just an added benefit from of threading a heim joint on them.
ORIGINAL: supraman408
I can vouch for the rosehill units. he is a good friend of mine and makes good stuff. Why don't you make a set using your original strut rods? My web page is for doing it is about making them for a 65 but the technique could be adapted.
home made adjustable strut rods
Dragonus18
Sep 9, 2015 01:21 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 04:12 PM
