The Date Code
Old Feb 13, 2008 | 07:56 PM
cmdavis's Avatar
cmdavis
Default The Date Code
I read, and I could have read wrong, that in order to determine the originality of the engine you have to tell if the date code on the engine and transmission are within one month of the date of production. Now if that is true, where is the date code on the engine block?
Old Feb 14, 2008 | 04:35 AM
kalli's Avatar
kalli
Default RE: The Date Code
not too sure about it, but head the same.
First thing to check if it's the proper kind of engine, which you can check on the engine code in the VIN.
As for the date code. on my 289 I found it between the distributor and the oil pressure feeler).
Close to the distributor, right under the head.
I'll try and make a picture.
Old Feb 14, 2008 | 08:26 AM
d_ford's Avatar
d_ford
FE engines have the date code cast just below the oil filter base. I'm thinking the 289-302's are around the oil filter mounting pad too.
Old Feb 14, 2008 | 10:01 AM
sixtysix's Avatar
sixtysix
I think the code is behind the starter on a 289. Scott
Old Feb 14, 2008 | 10:52 AM
kalli's Avatar
kalli
sixtysix,
the casting number is just above the stater, that's correct.
on ford blocks there's usually an additional date code on a different location.
I found a picture of a block on ebay, and added where I got my datecode (i hope that's the correct code)
[IMG]local://upfiles/52145/A5A80EEA49AA443EBAA68E22E6167C0F.jpg[/IMG]
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
