*[LOWERING]* Need photos
Old Feb 18, 2008 | 06:22 PM
1970coupe's Avatar
1970coupe
Default *[LOWERING]* Need photos
I have a friend who has his own shop and lowers all of his old hot rods and says he can cut the coils on mine and lower it how i want in the front. But i need some photos of some of yalls stangs so i can show him about what i want. Also what kind of rear leaf would you use to lower the rear? Someone told me the reverse eye leaf might be too low and to go with the mid-eye.
Old Feb 18, 2008 | 06:57 PM
Loza_69Mach1's Avatar
Loza_69Mach1
Default RE: *[LOWERING]* Need photos
Is cutting the coils the best and right way to lower your car.....
Old Feb 18, 2008 | 07:25 PM
1970coupe's Avatar
1970coupe
yes its fine as long as you dont heat them up with a torch like most morons doto lower the springand make them brittle. it will give me a stiffer ride also. the 620s arnt quite low enough for me.
Old Feb 18, 2008 | 07:55 PM
Mustangdemon67's Avatar
Mustangdemon67
dont cut the springs, do it the right way and buydifferent sizesprings
Old Feb 18, 2008 | 09:39 PM
Iskwezm's Avatar
Iskwezm
620's will probably not give the ride height your looking for. I cut 1 coil from my 620's.
I wouldnt cut old coils either
Old Feb 18, 2008 | 09:45 PM
1slow67's Avatar
1slow67
ROTM Moderator
Get new coils and cut those.
Old Feb 18, 2008 | 11:27 PM
1970coupe's Avatar
1970coupe
whats wrong with the old ones
Old Feb 19, 2008 | 01:28 AM
mat11089's Avatar
mat11089
I used 620's cut a coil and used 4.5 mideyes my pic is in my sig.Not a real smooth ride but on a flat road its awesome and handles awesome..
Old Feb 19, 2008 | 04:06 AM
Reverb's Avatar
Reverb
Don't older coils get work hardened as a by product of them bouncing up and down all the time? Making them brittle anyway
Old Feb 19, 2008 | 12:42 PM
66FB06GT's Avatar
66FB06GT
Here is some info on my experience with lowering springs (and also cutting them):
http://www.fastbackmustang.com/Proje...ngInstall.aspx
I was supposed to get the 620's but they sent me the wrong ones (same size and everything just a stiffer/stronger spring). I cut a full coil w/ a hack saw to keep it from getting too hot. I used 5-leaf Mid-Eyes out back, but wish it was about 1/2" lower. I have some pics on the site of the stance, and a ton more if you would like to see others.
Good luck.
