200 ci to 302
Howdy,
I have a 1966 Mustang with a 200ci and a three speed manual. I want to drop a bigger motor into the car. Preferably a 302. I talked to a mechanic and he said that I can probably pick up a 302 with a tranny, a correct length drive shaft for about $500. Is there anything else that is needed for the conversion. Some people have told me that I need to convert the wheels to five lug and that I will need a whole new front end. What is true and if anyone has done this I was wondering if you could send me some info.
Also is there a particular 302 that should be used (What year and Carb or Fuel Injected).
I can't say for shure on the 66 but the 200 CID I6 made it into the fox stang until I think 82or 83 and the K-MEMBER IS NOT compad with the one used for the V-8
I have done a coupple I4 to V8 swaps and the EFI is better for a mild combo or close to stock . But the carb is the easyest and cheapest way to go . you cot a lot of work to do and the EFI just makes more of it . stay with the older block and heads they make more power and have bigger valves and higher compression (pre 1971) .
You stick that Boss motor (will not fit anyway) in that 66 or a strong 302 in a 6 banger car, and you’re looking to strip off the lug nuts in a race.
All wheels need to be converted to a 5 bolt pattern and upgrade the breaks and suspension.
It is much easer to either:
1) Performance enhancing the I6 will bring the HP up to a stock 289 2V
or 2) start with a former V8 body.
The Boss/Cleland motors are to big for the 65/66 cars, but a 351W works.
Cheers,[sm=icon_cheers.gif]
what is the wight diffrence , how mutch could it be ihe I6 is real heavy remeber the blocks are hallow inside so looks could be deciving . my fox stang is a ornigal I4 and has the I4 springs with the small block . It dose not squat or handle like a POS . I dunno .
Is the k-member compad between the V-8 & I-6 in 1966
