302 clutch?
Old Feb 19, 2008 | 07:01 PM
tnyankee's Avatar
tnyankee
Default 302 clutch?
A buddy of mine is trying to bolt up a manual transmission in his 68, the problem is that the 302 in the car doesn't have the mounting hole for the engine side linkage to screw into. Is there something missing? I thought most of these had a specific hole for that particular part for use with a manual transmission? Thanks!
Tony DiMaiolo
Old Feb 19, 2008 | 07:10 PM
Adrenolin's Avatar
Adrenolin
Default RE: 302 clutch?
Whats the 'particular' part your talking about? The bellhousing?
Old Feb 19, 2008 | 07:14 PM
tnyankee's Avatar
tnyankee
It's the engine side equalizer bar pivot. He can't seem to find out where on his engine it goes to use the equalizer bar. There is no provision for it on the bellhousing or the block itself.
Tony DiMaiolo
Old Feb 19, 2008 | 08:12 PM
Aussie66Fastback's Avatar
Aussie66Fastback
is he trying to set up a mechanical clutch mechanism?
if you can get some pics it would help
Old Feb 19, 2008 | 08:18 PM
tnyankee's Avatar
tnyankee
Yeah, he has all the mechanical parts. He is on a tight budget... so this is how he is wanting to go. I'll try to get some pics from him soon! Thanks!
Tony DiMaiolo
Old Feb 19, 2008 | 09:09 PM
Mustang Dad's Avatar
Mustang Dad
Sounds like he is talking about the Z bat for the mechanical clutch. The pivot he is talking about mounts on the left rear side of the block and is a kinda universal fitting to hold the inner part of the Z bar and allow it to move with the engine when it torgues up. There should bea threaded hole in the left rear of the block for this pivot point.
Old Feb 19, 2008 | 09:42 PM
Aussie66Fastback
yes, Mustang Dad,
when i put the current 302 in my 66 it was a later block and the threaded hole wasnt present.
I cant remember what we had to do to fix it but it is not insurmountable
Old Feb 20, 2008 | 01:46 AM
67mustang302's Avatar
67mustang302
There's a steel bracket that is sold that bolts on with the bellhousing and has the mounting provision for the z bar setup. It's just 2 bell housing bolts that hold it there, pretty simple fix.
https://www.mustangsplus.com/xcart/p...514&page=1
Old Feb 20, 2008 | 10:27 AM
tnyankee's Avatar
tnyankee
Excellent... that is what he is looking for! Thanks for all the help!
Tony DiMaiolo
bradleyb
Nov 27, 2015 07:50 PM
Thunderball
15
Nov 22, 2015 11:49 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
