help?
Old Feb 20, 2008 | 04:57 PM
66blownmustang66's Avatar
66blownmustang66
Default help?
im rebuilding a 93 5.0 (302), im going to use the stock crank, i want to buy forged pistons, i was wondering what you people think stock 302 rods can handle?? because forged h beam rods are a little out of my budget right now.. i got afr 185 heads on order.. any other suggestions...
Old Feb 20, 2008 | 06:51 PM
mustanglover66's Avatar
mustanglover66
Default RE: help?
What kind of power and rpms are you planing to run that will help figure out if the stock I beams can handle it. I'm not sure about stock but aftermarket I beam can handle up to around 450 hp.
Old Feb 20, 2008 | 09:29 PM
Scott H.'s Avatar
Scott H.
Default RE: help?
Old Feb 20, 2008 | 09:41 PM
JMD's Avatar
JMD
Default RE: help?
+1 I have read that the stock rods are pretty good when the rod bolts are upgraded.
Old Feb 20, 2008 | 09:56 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: help?
hey scott...explain shot peened rods???
apparently mine were done...sounds cool. never understood what it meant tho
Old Feb 20, 2008 | 10:43 PM
Starfury's Avatar
Starfury
Default RE: help?
Basically you stick the rods in a rotating cylinder full of steel shot. As the shot pounds the exterior of the metal it relieves the stress in the grain structure, increasing the strength of the metal. The detailed explanation is kinda complicated metallurgical speak, but that's the general idea
Old Feb 21, 2008 | 12:16 AM
67mustang302's Avatar
67mustang302
Default RE: help?
You can get decent 4340 forged I beams that'll take more than the block will for like $200-300. I'd do that just to go with a floating pin setup, I dunno if I'd want to put boost on a non floating pin if you're gonna be pushing the limits of the block, but that's just me. Find out what it costs to get your rods improved, then go with what costs less.
