C4 Tran what gears to use ?
So I have a freshC4 Trans with stock 300 gears in the rear. I want to change to a posi , what would be a good set of gears to install. I don't do alot of highway driving maybe 55 to 60 mph tops. I just wanting to know high to goand what RPM to expect with the gear changes. I was thinking 355 . The motor is a 289 ,mild cam, with headers , 600 Carb.So if anyone has any suggestion I would Like to hear them.Thanks
ORIGINAL: 65Coupester
A good compromise is 3.25.Good performance around town but OK on the freeway.
I pull about 2400 rpm at 55.
Here, check out these calculators. More info here than you could ever use.
Cheers.
http://www.wallaceracing.com/Calculators.htm
Cheers.
Im going to put in 3.55s or 3.73s in my car with either a Detroit locker or a Detroit tru-trac. It is an 8 inch axle. Im not sure which of the two I will pick, but I have 29 inch tall tires as of now (not for long, next set will be a size shorter). So I will probably go with the 3.55s since I don't have overdrive.
