smoking from value covers
Old Feb 23, 2008 | 05:00 PM
krobillard's Avatar
krobillard
Default smoking from value covers
I'm not sure if this setup is correct, the guy at Auto zone said it is not. So here's the question. Its aRebuilt engine ( Less than 500 miles)so when I got it back from the non-name rebuilder ( retired mechanic) said it's fine. On the driver side of the value of covers is a cap breather ( were I put the oil) on the other side (passager side) is were the PVC value is at andhoes going to the of the carb plate. Its seem tobe smoking alot at the PVC inlet. I replaced the PVC value.Doesthis setup sound correct and how can I stop that side from smoking so much? Thanks.
Old Feb 23, 2008 | 05:21 PM
jlg2002's Avatar
jlg2002
Default RE: smoking from value covers
some smoking is normal because the rings are not yet fully seated. There should not be an extreme amount though. If in doubt have another qualified mechanic check it and get their opinion. Its PCV not PVC BTW.
Old Feb 23, 2008 | 05:45 PM
67mustang302's Avatar
67mustang302
It seems like there are so many cars around here with PVC....it's a wonder it doesn't melt.
How much smoke? Just a little bit, like a few wisps? Or is it like a steam locomotive?
Old Feb 23, 2008 | 05:47 PM
jlg2002's Avatar
jlg2002
yeah, +1 on that. Too much PVC action going on here.
Old Feb 24, 2008 | 06:52 AM
kalli's Avatar
kalli
the setup itself sounds ok. what does it do when the engine is running and you pull the breather cap ?
Old Feb 25, 2008 | 12:18 PM
krobillard's Avatar
krobillard
Its starts to smoke, on both sides especially if the engine is hot. That is were it all started, I try to replace the PCV value with just a cap cover, and it started smoking alot and the engines RPM's were very high. After replacing the PCV value with a new one it all went back to normal, and a little smoke was coming from the rubber seal that the PCV value sits in, it's pretty lose.
Thanks
Old Feb 25, 2008 | 12:20 PM
Fordication's Avatar
Fordication
Well thats what you get when you buy a car with value covers and PVC. Spend some money next time and get some good valve covers and PCV.[:@]
Old Feb 25, 2008 | 12:30 PM
TexasAxMan's Avatar
TexasAxMan
Ooooh, harsh! Funny, but harsh.
Old Feb 25, 2008 | 12:38 PM
JMD's Avatar
JMD
How about something helpful?
I am a little worried about the "smoke when hot" thing. It makes me worry if it might be "steam when hot" instead.
Check your dipstick and oil cap for evidence of water in the oil. If in doubt, change your oil. If the problem persists, you may have an intake manifold sealing issue.
Old Feb 25, 2008 | 05:23 PM
kalli's Avatar
kalli
+1 on what JMD says
and if your car is smoking out of the valve covers like mad, then you might have trouble with your piston rings
as mentioned above, check what it does when you pull the valve cover cap when running.
if it smokes a lot, then check on compression
