Attn all Engine Builders!!!
Old Feb 23, 2008 | 10:44 PM
silverblue66's Avatar
silverblue66
Default Attn all Engine Builders!!!
I know a lot of people here are either proffessional engine builders/machinists or have dealt with them. what i want to know is is 1700 a good deal for a 289 rebuild at a reputable machine shop. this does not include the heads because they are already rebuiltand had some bowl blending done and larger valves(800). it also does not include rotating balancing.
Old Feb 23, 2008 | 11:02 PM
67mustang302's Avatar
67mustang302
Default RE: Attn all Engine Builders!!!
It depends on what parts are going into it.
Old Feb 23, 2008 | 11:12 PM
silverblue66
mostly stock. flat top pistons cast or hyper, im not sure. comp cams hyd flat tappet cam. everything else is stock.
Old Feb 23, 2008 | 11:16 PM
67mustang302
If it's assembled well then that's not too bad. Make sure you at least upgrade to some ARP rod bolts, the factory rod bolts are a joke. And ABSOLUTELY follow AAAALLLLLLL of the instructions for the cam break-in procedure. Down to the most minute detail. If you go with cast pistons then you might as well go hyper, they'll be a bit stronger, and depending on who made them, lighter. Just make sure your tune is right, if you detonate on hyper pistons they're prone to cracking.
Old Feb 24, 2008 | 06:10 PM
silverblue66
thanks. is it worth it to do a rotating balance? my cams redline is 5200.
Kip
Old Feb 24, 2008 | 06:50 PM
67mustang302
Get it dynamically balanced. And you could prolly get a slightly bigger cam if you're looking for more power.
Old Feb 26, 2008 | 10:06 AM
silverblue66
thanks
Old Feb 26, 2008 | 10:28 AM
urban_cowboy's Avatar
urban_cowboy
A full rotating assembly is going to be a large chunk of that. Are you getting new rods and crank with that? What are they machining? Ask lots of questions. The last thing you want is a rebuild with a crank or rods that have not been touched. You can turn a crank and reuse it, but just ask the questions of what does that price include?
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
mungodrums
Oct 7, 2015 04:01 AM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
