fuel pressure
Old Feb 24, 2008 | 11:02 PM
SalikDDD's Avatar
SalikDDD
Default fuel pressure
whats the fuel pressure supposed to be anyway? i believe part of my over rich problem is due to no regulator at all on this car and i'm drowning the carb out with gas. - it's a 110gph pump thats delivering 6.5-10 psi or so - i need to regulate it down some , but i don't know to where, anyone know?
everyone knows my specs i think..
289 .30 over
gt40p's
holley 600 cfm
performer rpm
xe268h
tri y's
etc
thanks!
Old Feb 24, 2008 | 11:18 PM
Gun Jam's Avatar
Gun Jam
Default RE: fuel pressure
6.5 is just above tolerable upper limits (too much)
I suggest between 5.5 and 6 lbs
hell they will run just fine at 1 pound assuming the pressure never drops much below that under heavy acceleration
-Gun
Old Feb 24, 2008 | 11:34 PM
SalikDDD's Avatar
SalikDDD
awesome, i guess tomorrow i'll set out on making a fpr :| maybe this will solve my drowning problems.
Old Feb 24, 2008 | 11:53 PM
Gun Jam's Avatar
Gun Jam
how do you plan on making it....by going to work and using the money you made at work to buy one from summit?
Old Feb 25, 2008 | 12:00 AM
SalikDDD's Avatar
SalikDDD
no, i've made them before, along with boost bleeders/controllers etc.
Old Feb 25, 2008 | 05:24 AM
kalli's Avatar
kalli
actually some carbs (holley street abenger) want constant 5-7lbs pressure (no more, no less).
Check the carb manual. but if you can make a pressure regulator, then I'd set it to 6 max and see how that goes
Old Feb 25, 2008 | 10:01 AM
Art Brock's Avatar
Art Brock
Not trying to hijack your post but I may have a similar problem. I put a mechanical Holley 110 on my car late last year.
It is harder to start now & doesn't seem to idle as good. Seems to run OK though. I was thinking the carb was the problem but is it possiblethe fuel pumpis too big?
Motor is stock 1993 Cobra302 with Edelbrock Performer & Holley Vac Sec 600.
Old Feb 25, 2008 | 12:49 PM
Gun Jam's Avatar
Gun Jam
I doubt the fuel pump is too big.
just because it can delver 110 gallons per hour doesn't mean the car has to use 110 gallons an hour of fuel.
at idle the floats are nearly closed and allow only a very small amount of fuel to drip in.
The springs for your inlet needles might be weak and allowing more fuel in than is necessary.
-Gun
Old Feb 25, 2008 | 01:02 PM
JMD's Avatar
JMD
Aftermarket fuel pumps routinely run more pressure than carbed cars want. This goes for mechanical pumps as well as electrics.
I will admit to never owning a fuel pressure guage..... I just keep turning down the pressure or the regulatoruntil the car stops flooding..... does this make me a bad person???????
Old Feb 25, 2008 | 03:03 PM
Gun Jam's Avatar
Gun Jam
I have a mechanical fuel pressure gauge.
im using a stock carter AFB 600
a carter high volume fuel pump
i get 6.1lbs unregulated works fine for that particular carb
If your carb cant handle 6 pounds you can probably get improved needle springs that will allow it to operate at the 6lb range.
personally if i was running a 4 barrel carb that couldn't handle 6lbs I would make it handle 6lbs or throw it away and get one that will handle 6lbs before i ran a regulator
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
mrappe
Sep 26, 2015 10:16 AM
