’68 keeps slipping into n
Old Oct 10, 2003 | 07:38 PM
nnikirk's Avatar
nnikirk
Default ’68 keeps slipping into n
This is the first time I've posted here. I'm having a problem with my '68 slipping into neutral when Ifirst start going. The shifter remains in drive, so it's not just a loose shifter. It will continue to do this until I have driven for several miles. After that, itI don't have any more problems. This just recently started. Any ideas about what the problem could be?</P>
</P>
Thanks for the help</P>
Old Oct 10, 2003 | 08:43 PM
67aquafastback's Avatar
67aquafastback
Check the fluid level (auto trans) If fluid level ok then your seals may be getting worn or your band adjustment is out. If level is ok you can try to add some transmission additive that helps with slippage. The stuff works it is a fix but trans will one day need a rebuild.
Old Oct 12, 2003 | 11:35 PM
vfast's Avatar
vfast
I ♥ Acer
make sure all the linkage is in great working order. if no leaks pull the pan and change filter and new fluid.what color is fuild now?any burnt smell..I also agree with the adjustment this can be done when changing fluid
JoshyGT
Sep 19, 2017 08:52 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Webster454
Sep 23, 2015 06:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 11:50 AM
