rear seatbelts
Hi all-</P>
I am installing newrear seat belts in my 65 coupe. They came with reinforcement</P>
plates, bolts and lock washers. My question is since there are no pre-drilled</P>
holes in the floordo I just space the belts 15" apart,since the seat pattern is 15"</P>
wide, drill the holes through the floor and that's it? Any help would be ppreciated.</P>
Thanks,</P>
Rich</P>
</P>
</P>
Originally Posted by bigchalupa
there is no place for rear seatbelts? where were they connected before</P>
There were none there. 65's weren't required to have rear seatbelts</P>
</P>
wow, that's wierd, guess you learn somthin every day, i was just wonderin, cause ive never seen ANY mustang w/o rear seatbelts. I wouldn't know what to do, what you suggested doesn't sound to stable
Find a 66 that has rear seat belts and take your measurments from it. Install your in the same location and you should be fine. I am sure most any older stang owner would be happy to help. I have a 67 fastback so mine will be differnt than your.
