More numbers
Old Mar 3, 2008 | 06:18 PM
LPlum's Avatar
LPlum
Default More numbers
My neighbor has a 65 coupe, and I have a 66 coupe.
The 65 has a plate riveted to the inside of right fender. It reads:
2F15
65A
F22RM
Can anyone tell me what the numbers mean? The 65A=2door
hardtop.
Should my 66 have a similar plate?
Thanks, Lowell
Old Mar 3, 2008 | 06:22 PM
connor90's Avatar
connor90
Default RE: More numbers
it should have a similar plate...but theyre on the doors so who knows what could have happened to it. go here, this should decode it for ya
http://www.mustangdecoder.com/
Old Mar 3, 2008 | 06:25 PM
6marc5's Avatar
6marc5
Sounds like the buck tag,although I believe they are screwed on.
Old Mar 3, 2008 | 06:27 PM
connor90's Avatar
connor90
pretty much...well actually if you want to get techinal they are rivets
Old Mar 4, 2008 | 11:07 AM
LPlum's Avatar
LPlum
Thanks for your reply, but I'm not talking about the door warranty tag. 6marc5 may have it right, he called it a buck tag. It is fastened to the right inner fender, under the hood. I guess it was just attached with to screws. This tag is about 2" X 3". Thanks for any help with these numbers.
Old Mar 4, 2008 | 11:19 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
a lot of time the buck tack are broken off etc. it might have been a different spot depending on which factory made it.
Old Mar 4, 2008 | 11:40 AM
Adrenolin's Avatar
Adrenolin
Post a pic of it sometime. I've never seen one on a mustang myself.
Old Mar 4, 2008 | 12:24 PM
connor90's Avatar
connor90
hmmm...well post a pic if you can. ive never seen one of those tags
Old Mar 4, 2008 | 12:28 PM
retro77's Avatar
retro77
I had one on my mustang when I bought. I tookit off to decode it now its in a box somewhere...
Old Mar 4, 2008 | 04:17 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
In '65-'66 the only plant that used buck tags was the Metuchen, NJ plant. The tag was to tell the welders/body workers on the assembly line about anything that needed to be done to that particular body in the way of holes, braces, brackets and such. This was dependent on the options for the car.
