Cable Clutch Question!!!!
Old Mar 4, 2008 | 12:47 PM
66 FastBach's Avatar
66 FastBach
Default Cable Clutch Question!!!!
is there a way to adjust a cable Clutch?? i have a T-5 with a cable clutch set up and was wondering is there a way to adjust the play in it??? there is only a few inches from engaging and dis-engaging. or is that normal.
Old Mar 4, 2008 | 02:57 PM
gothand's Avatar
gothand
Default RE: Cable Clutch Question!!!!
You can adjust where it disengages/engages relative to the floor, but you're not going to easily change the pedal ratio. A few inches between engaged and disengaged sounds about right.
Jeff
Old Mar 4, 2008 | 03:00 PM
JMD's Avatar
JMD
You should be able to adjust the cable where the cable hooks to the throwout fork. If you have a MustangSteve setup,it may havean option that allows adjustment on the firewall as well.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
