Tremic-5spd Question
Old Mar 4, 2008 | 08:05 PM
66 FastBach's Avatar
66 FastBach
Default Tremic-5spd Question
i am going thru my car top to bottom and i want to service my Tranny--mainly check the fluid level. is there a site with the info i need?? like were is the plug i take out to check level--how high the level should be and what fluid to use. thanx to all for all the previous info i have gotten on this site.
Old Mar 4, 2008 | 08:25 PM
Daze's Avatar
Daze
Default RE: Tremic-5spd Question
Is this a T5 or a 3550?? If it is a T5 the fill and drain plug is on the passengers side NOT THE DRIVERS SIDE there is a pivot bolt on the drivers side that if you unscrew it you will need to pull the trans apart. I would not check the level, I would change the fluid.
1. remove the drain plug
2. let the fluid drain
3. put the drain plug back in
4. remove the fill plug
5. refill trans
Note non WC T5 use gear oil,and WC T5s use ATF fluid
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
