Quarter panel drain plug valves?
Can someone explain where these are?
RE: Quarter panel drain plug valves?
I need this answer also. I got a entire plug set and haven't figured out what to do with these.. :)
[IMG]local://upfiles/55108/2B69BBDFF1B94294B1819F7C6B3070D3.jpg[/IMG] |
if im not mistaken they arebetween the rear tire and the bumper,where the quarter panel curves on the bottom hope you can install them i just got mine, tried to put them on butno luckheres a pic a drew a circle where they go mines a 65 hopefully it helps http://s207.photobucket.com/albums/b...100_1106-1.jpg
Mine look totally different than the ones pictured above. I got a 33 peice plug kit and have replaced everything I could find. Just have these quarter plugs left and a few others (which I think I dont need cuz I have an early 67). I'll look again...
yea.. sorry... mine's a 65...
ORIGINAL: baddog671 Mine look totally different than the ones pictured above. I got a 33 peice plug kit and have replaced everything I could find. Just have these quarter plugs left and a few others (which I think I dont need cuz I have an early 67). I'll look again... |
The drain plugs should go in the trunk drop off where it meets the quarter panel.
ORIGINAL: guybored if im not mistaken they arebetween the rear tire and the bumper,where the quarter panel curves on the bottom hope you can install them i just got mine, tried to put them on butno luckheres a pic a drew a circle where they go mines a 65 hopefully it helps http://s207.photobucket.com/albums/b...100_1106-1.jpg |
Ok, I think I found where they go. The problem was that I do not have the originals still installed, so it was harder to find the "hole" where they go.
Now a new question. The hole is actually a small square and on the back side of the grommet are little prongs that hold it into the opening, so its not a standard grommet. The grommet has a special shape to it, forming some function, but I dont understand it's function? |
We all know where they go, well not exactly. I posted this same question last year when I was wondering what they were. We need a pic of the exact location.
[align=left] [/align] |
