Car won't start
Old Mar 10, 2008 | 01:13 AM
djfrog2001's Avatar
djfrog2001
Default Car won't start
I have a 69 GT with a 302 that won't start. I'm getting power to the ignition coil terminals but not to the primary cable to the distributor cap. I haven't yet really starting digging in to it but I was wondering if anyone here has had a similar problem.
Old Mar 10, 2008 | 09:56 AM
Daze's Avatar
Daze
Default RE: Car won't start
if you are not getting power out of the coil than it is either the coil or the distributor/module if you have EI. The distributor acts as a trigger to complete the circuit and then brake the circuit on the coil this causes the high voltage spark to be created. I would start with the distributor by disconnecting the negative cable from the coil and putting the leads from a meter on said negative cable and ground checking of continuity. Then turn the car over. Continuity should switch back and forth from on to off. If it stays off or on with out switching you have problems in the distributor or ignition module if it is electric ignition. If that is the case let me know and I will give you further info on troubleshooting the distributor. If the distributor checks out and you are getting the switching than the coil is bad and you need to replace it.
Old Mar 10, 2008 | 03:34 PM
jlg2002's Avatar
jlg2002
The terminals are the primary side of the coil. are you saying you have no spark out of the secondary side? If so the advice provided by DAZE is appropriate as well. If the points don't open and close the coil cannot make the magnetic field it requires to fir into the secondary.
djbigskrilla
Sep 20, 2022 01:04 AM
msavoia23
12
Jul 7, 2018 12:08 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
