Start up problem
Old Mar 11, 2008 | 05:49 PM
toonspeed's Avatar
toonspeed
Default Start up problem
69 (302) and it was starting/running fine for a few months. Thena couple weeks ago Iturned the key and heard nothing. I replaced the solenoid and could hear clicking when turning the key. I replaced the starter and heard nothing when turning the key. I used the solenoid from another car and the engine started right up! Thought I had bought a busted part so I put the original solenoid back on and the car started and ran. About 8 hours later (clock on passenger side stopped) it went back to hearing nothing when I turn the key.
What steps should I take to find the problem?
Old Mar 11, 2008 | 05:56 PM
jc92073's Avatar
jc92073
Default RE: Start up problem
Have you made sure every connection from the battery is clean and tight? Check the battery ground also. If you bypass the solenoid will it crank?
Old Mar 11, 2008 | 06:00 PM
Gun Jam's Avatar
Gun Jam
so you replaced all that stuff and never thought "Hey maybe i should clean my battery post and attempt to charge the battery" ????
-Gun
Old Mar 12, 2008 | 03:33 PM
jlg2002's Avatar
jlg2002
You may have a bad + or - battery cable or loose ground. As Gun Jam says, look,for obvious looseness and corrosion first, then replace both these cables. Also, turn the headlights on and observe what happens to the head lights when the engine is cranked?
Old Mar 12, 2008 | 09:28 PM
flyingfool's Avatar
flyingfool
I second the clean battery terminals. I had a few times where my car wouldnt start cuz they were just a little grimy. even a quick pass with sand paper helps
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
