ADVICE ON WHAT ENGINE SHOULD I USE?
I got a 69 mustang and trying to decide what engine to use for this project. can you guys give me some advise?
there is a junk yard close to my house nad i was thinking of going there and get a used block since they having a sale 50% off this weekend.
Im have a low budget.
thank you
thank you
Big blocks are expensive to build, and they take work to make them fit. Plus they make the car even more front heavy and aren't really necessary for a street car. 351W if you can find one.
351w stroked to 393-408, if you want a daily driver with massive power/economy a 5.0 roller motor with twin turbos off t bird tubo coupes, easy 450-500hp using mostly stock and junkyard parts and better than stock 5.0 economy in NORMAL driving conditions. Or stroke a 351w the same power but at lower rpms and cheaper.
^ wtf[&:]
i'd totally grab the 429 if its that cheap - rebuilding them if you need to is NOT that much more money, and you wont need to spend as much in go-fast parts to actually make it perform.
